Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Looks like a cheaper version of the more famous Technics SL-10. Not sure about the J2, but the SL-10 had a mechanism on the inside that pushed down on the record so you could actually move the turntable while it was playing and it wouldn't mess up. Technics boasted that it would even play upside down! I wouldn't try it with the J2 though, it doesn't have a similar mechanism it appears. Linear tracking arm, only took a P-mount cartrdige. But it's my understanding the SL-10 has quite a following - it's the exact size of an album cover.
The SL-10 sold for $620 new from '80 to '84 but the J2 was only $200 from '84 to '85. Looks like they have the same specs on paper, but build quality is much better on the SL-10 I'd imagine. Probably not a bad deal at $35 - you could do much worse.
I remember the "J" series of narrower Technics components. At the time, I assumed the "J" stood for "Junior," referencing the width.
My first CD player was a Technics SL-PJ1. I remember that there was a linear tracking TT available that was designed to visually "match" the CD player. The CD player was unusually deep which was probably to allow someone to put one of the J2-type TTs right on top, not that I'd want to with all the heat that little CD player put out. I do think Technics had more than one version of the narrower "J" linear tracker because the one from your Craigslist ad doesn't look exactly the way I remember.
Here's a photo of an SL-PJ1 CD player that I found on the web:
