Ginger Clark
I started with a perfectly good turntable that I've had for years and feel like I've made it unusable. I need someone to help me fix it.
First, the records started not sounding right, not being clear, cutting out. I decided it was the needle. Removed the Stanton 631 and replaced it with a new AT-3600-L. However I did it in place, and didn't realize until I was almost done that I could remove the headshell so I stood on my head to install the screws.
Meanwhile, although I'd unplugged the power, I hadn't unplugged from the amplifier. When I reached in the back to do that, I realized that the plugs weren't seated and I probably hadn't had to replace the needle after all. (drats!)
I was far enough into it that I just continued. I'm using Mitsubishi's instructions for installation. the only piece of info I didn't have is something called an Overhang Gauge to adjust the stylus. So I put it in the middle of the slots. I then followed the instructions for adjusting the tracking force, tonearm height, stylus height and counterbalance weight.
But maybe I've put some stress or other on it and that wonderful tracking device that holds the arm, no longer goes back to its start. When it tries to, it sets off a chattering noise. That, and the needle doesn't clear the record anymore.
As I said, I need a hand here and I'm hoping someone knows of a pro in southern California who can give me a hand. I could start over, reinstall the old cartridge and follow all the instructions for balance, etc., but I've gotten kind of timid about this. Really don't want to screw tis up any further.
