MuseChaser
Here's the situation/mystery...
Approximately 180' deep well with one or two-year-old submersible pump.. Even newer pressure tank, T-fitting, gauge, and pressure switch set to 30lb min/60lb max. All that works as intended; once the pressure gets down to 30 lbs, the pump kicks on and pressure slowly and steadily rises to 60 lbs and the pump kicks off.
This feeds a relatively recent water softening system, easily bypassable by throwing three ball valves. This, in turn, feeds a rather involved water treatment system installed about two years ago for free by the county or other governmental body (can't remember which) due to a contamination settlement against a local builder who engaged in unsafe and illegal disposal practices, thus contaminating the water table in the immediate area.
I mention all of that only for completeness; it's all been working fine since installation. However, as I was assisting the owner in opening his pool for the season and using an outdoor hose bib on the side of his house to bring the water level of his pool up to the required level, he informed me that he had NO water anywhere in his house.. none of the sinks, toilets, or other fixtures delivered any water at all. The pressure at the hose into the pool seemed weaker than it should be to me, too. The home has a full basement, and the hose bib is fed by one of the lowest pipes in the house and controlled by a ball valve approximately halfway up the foundation wall. The home has two stories above the foundation, with the laundry and a sink in the basement, a half bath and kitchen sink on the first floor, and two full baths (total of three sinks, one shower stall, and one tub/shower) on the second floor.
While we were filling the pool, I monitored the pressure gauge on the tank and it indicated as it should (as described in the first paragraph above). There is a water flow meter incorporated into the treatment portion, and that water flow read properly as the pool was filling.
I tried bypassing the water softener system, but that made no difference; still weaker than expected flow to the pool hose, and no water at all in the house. Shutting off the hose restored water to the house, regardless of whether or not the softener setup was in the system. There is no way to bypass the county-installed treatment system.
The owner is still running into the same issue; when the hose is running, he has no water in the house, although he reports that the water pressure at the hose, or within the house when the hose is off, is stronger again.
I can't for the life of me figure out what is happening. Does anyone have any ideas? Thanks in advance for any suggestions.
edit: The owner also has a whole-house sediment filter coming off the main pressure tank. I replaced the dirty cartridge within it with a new one hoping that would help, but it didn't.
