josephdaniel
vitam vivere pro teipso
This is going to be a long post with a lot of information!
I have a Montgomery Wards WG-2694A console that I have been working on for the past month in my spare time.
When I received it the amplifier section was working well, however the AM side would only receive our two local stations and the band is very quiet (no static). On the FM side there was a normal amount of static, but it wouldn't receive any stations.
I assumed there was a combination of weak tubes in the tuner section and possibly failed paper capacitors along the signal chain. All of the tubes tested fine on my simple emissions tester. I moved forward with ordering an appropriate assortment of replacements for the paper and electrolytic capacitors in the set hoping for an easy fix.
After recapping the set the amplifier works beautifully, however there was no change in the performance of the tuner. I checked the resistance at each of the test points notes in the schematic (see attached files) and there was nothing glaringly out of tolerance. I also checked some voltages throughout the tuner section.
I noted that the grid voltage of V2 (6AU6A) was positive which in my (likely flawed) understanding of the schematic points to a failure of the FM local oscillator. I checked with a second radio and could hear the AM oscillator running, but nothing coming from the FM side.
I tested the FM RF amp / converter tube (V1 ECC85) again to verify it's condition. I also cleaned the pins as best as I could. To no improvement. The tuner assembly is encased in a solder sealed box that is also soldered to the main chassis and will be very difficult to access without creating further issues.
After that I tested additional voltages around the tuner mostly (see attached file) and noted some irregularities. I am not well versed enough in electronic theory to full understand how each component in the circuit affect one another.
Any thoughts on where I should look next for my issue? I have a basic Heathkit IG-42 signal generator (I've never used it, but it's accurate according to my frequency counter) that I could use to inject a signal throughout the chain. I had thought about injecting a signal into the RF amp and then in the IF 1&2 to possibly narrow things down? However, I don't think there would be enough amplification in the circuit for it to do me any good beyond that point.
Help would be appreciated! I am still learning and trying to understand this stuff.
Attached is a copy of the schematic for this chassis, a copy of the voltage readings, and the resistance readings. On the table for the resistance measurements the values from the schematic are written on the right of each cell and the voltage measurements are formatted the same way.
