I purchased a Weltron 2001 8 track player from fleabay for a fair price, but the belt was off when I purchased it.
I checked another site and the ould belt was a 10.5 but mine takes a 11.5 and less width. So I ordered the correct belt and installed it but on install I noticed it riding all the way to the top of the flywheel. The old belt did the sME.
i PUT IT ON AND RAN IT A FEW IIMES AND IT WAS HIGH BUT REMAINED ON SO i PUT UNIT BACK TOGETHER.
wELL OF COURSE THE BELT CAME OFF 30 MINUTES INTO eLVIS HAHAHAHAH.
I looked at pictures of other mid belt machines like mine and all have belts riding in the center of flywheel.
I disassembled everything again to look and the motor pulley sits high on the motor spindle shaft causing the belt to walk up on the flywheel.
I do not see any adjustments unless the motor has been changed out.
Any ideas or help on this one is an odd duck for sure.
I found up and down play in the flywheel shaft around a 1/4 inch. Any repair? Any way to shim the flywheel up a little higher?
Can I dimple punch the flywheel to allow more belt grip?
