Kingsin7
Hey AK
I purchased some custom solid teak speaker cabs that already had a Werner Jagusch 2-way XO installed.
They were bought to accommodate my Altec 288-8G and 515B drivers.
I had a buddy come over with a directional mic, pink noise generator and some software installed on his laptop to try to get these tuned in.
I essentially stood behind the speakers and moved the horn and woofer wires to the different taps on the XO until he got readings he approved of.
We finally got them tuned-in according to the computer, though I was never quite satisfied with the bass.
These cabinets are probably too big to accommodate the 515 woofer's required pressure. They have 4 5X2" oval-shaped ports on a removable 3/4" bottom cover.
I believe they will need larger ports and some port tubes to allow for better pressure and air flow. My buddy ran the interior dimensions through his computer program, which spit out that two 6.5" holes that are 1.5" deep will be needed. I've plugged 3 out of 4 of those oval ports in the meantime.
Anyway, I'm working on that part too, but I wanted to reach out to the AK universe to see if anyone had a copy of the schematic for this particular Werner Jagusch XO...
I can then make sure that all the correct taps are hooked up and move on to cabinet issues such as baffling and new port holes/port tubes.
If anyone has anything to share, anything at all, please let me know!
Thanks
Thanks
