I only opened one side of the left W90, but the former owner said they were both alnico, so I never bothered to doublecheck. I'll have to do that soon. Look for a date on the rear of the woofer cones and also there might be a date in the upper compartment as well. Mine show an identical date on the left woofer AND in the crossover compartment. BTW, only remove the outside screws on the upper panel, not that one in the center (That holds one of the crossover parts in place, so leave it be).
That left woofer (black, ceramic magnet on yours) should be the one with the polystyrene "bung" over the cone. On mine, that side woofer is alnico (red banded), so I would imagine the same is true for the other three. W90's used closely-matched drivers. I should verify it, but the original brochure only lists the one Alcomax (alnico) magnet for both. Yours might be very-close to mine datewise. Crestwood23 has a pair with the same dates as mine (9/'63), but I believe his had a ceramic on one side like yours, so I got the impression that there is a transition period between, say, Fall of '63 and Fall of '64 (when they dubuted the "updated" versions, which I call the W*0B series) where they started making a couple subtle changes like the ceramic woofers, one then eventually two, adding the rear vent and eliminating the front port on one side, and splitting the upper and lower bass between the two woofers (Once they did that, it became a 4-way instead of a dual 3-way). It's damn-near-impossible to pin down all the little changes the company made along the way, but is it any different from most of the things we see today, with their Ver. 1, Ver. 2, and Ver. 2.1, etc.?
Your mids and tweets are free-air-mounted, right? No baffle? If so, then they should all be the same ones as in my W90's. Mine definitely have alnico Super 3's, and if you have at least one alnico woofer, then you surely have alnico Super 3's as well. Shine a flashlight through the grill. Point it upwards a bit instead of straight on if you have trouble seeing, but yours don't have the trim in the way, so it should be easier to see the side of the tweeter's magnet structure, which is painted gold and extends far back behind the cone. And the actual magnet won't be visible because it's enclosed. The mid will probably have a deep external magnet, painted grey, but it should still be alnico because it is much too-tall to be ceramic/ferrite. I am almost certain that the ceramic Super 3 tweeters were all baffle-mounted in the W90. As far as I know, if there's no upper baffle, then you have alnico mids and tweets, and those are some FINE-sounding drivers. I was playing some Spinners yesterday (mainly their stuff from like '69-'79) with the volume up loud enough to get the woofers moving a little air, and that stuff sounded like butter. The driver-to-driver integration on those is exceptional, so the sound is seamless, and horns sound like real horns on those. Same with old-school guitars, whether clean or overdriven, fuzzed-out or just a little dirt. I've been playing electric guitars for 30 years, and the W90's get it right. That old Fender P Bass and Jazz Bass stuff too.
Crestwood23 described the early '60's Wharfedale sound-signature best. He said it's like the old Vox AC30 guitar amps from the '60's, like the ones the Beatles used. That's the Wharfie midrange & treble in a nutshell. They have that "breath of life" in spades. Dynaco A25's have it too. Goodmans as well.
By the,way, your W90's have an alnico woofer on the non-"bunged" woofer, which is a good thing because that woofer puts out some sweet sound on it's own. Stick your ear up to it, and you'll hear those juicy lower mids and upper bass. The bunged woofer has a different sound (in mine). Not as juicy, more-neutral and not as open-sounding as the other. The two kinda balance each other out. If it had two regular W12's (alnico), I think the W90 would sound much more like the W60, which sounds lusher in the midrange and a bit more-British. That bunged woofer makes the W90's better with '70's stuff (The early W60 has an early '60's British sound, whereas the W90 has a slice of American in it and not quite as much lushness, so I see the W90 sound signature being a better for '70's classic-rock and the W60 sound signature being more for '60's jazz and classical and early to mid '60's rock/pop).
Dang... Did I type all that?
