thanks GT... think I'll go for it... trying to get in touch with the seller to go check them out... if I get them I'll be asking more questions for sure...
Can anyone tell how to inspect the tweeters on my W70s? I started to take some bolts off but decided to bag it. I was not sure of the proper removal. My W70s look very close to the ones posted several messages earlier.
If it were me, and I had tubes, I'd grab the earliest ones, the straight-up W70's with the ported cabs. My experience is with the alnico Super 3. I never owned a pair of Wharfedales with ceramic Super 3's before, but the alnico ones are dreamy. They have a smooth leading edge that reminds me of germanium transistors and germanium diodes. Perfect for classic-rock where the guitarists used those classic germanium fuzz & overdrive effects pedals with their amps (Hendrix, Page, Jeff Beck, Clapton, etc.).
I always recommend the W70 because it's still a hell of a deal. When you add tubes into the situation, there are speakers at the $2000-$3000 range that won't sound as good. Certainly for music made before, say, 1984.
Sweet looking 70's. Congrats! Hope I can find some closer to Oaktown.
thanks... I think I got lucky with these... guy had them listed on CL as "Wharfdale 70speakers", and I just happened to do a search as "Wharfdale" instead of "Wharfedale" and noticed them... otherwise, they probably would have been snagged before I came across them.
so, after reading all of GangTwangers comments on the W Series speakers, I happened to find a pair about an hours drive away and came home with them... seller didn't have anything to hook them up to give a listen so I took a bit of a gamble... figured for a buck thirty it was worth it... W70, cones marked 5/63, Alnico drivers throughout, driver surrounds looked good - one of the 12 inch looked to have dimples in the surround but fully intact otherwise, couldn't tell if they were foam or not... they sure don't give much room to pull the back panel away to open them up real well... they didn't have the oil caps... didn't have time to hook them up to test out, only had time to take a few pics... only damage other than some minor scratches were the back bottom corners, will have to do a repair there.
Front grills appear to be fixed in place.
Going to make some 60's retro stands, anyone know how tall the original legs were that came with these?
http://www.audiokarma.org/forums/picture.php?albumid=4142&pictureid=29447
http://www.audiokarma.org/forums/picture.php?albumid=4142&pictureid=29448
http://www.audiokarma.org/forums/picture.php?albumid=4142&pictureid=29450
Nice score. Those look great. I think you'll be very-happy with those. Keep us posted on their progress.
Regarding the Sangamo caps you mentioned, do they look similar to these 8mfd/600VDC ones from the '50's? If they do, then they are the same PCB-era type as mine (They are perfect for the alnico Super 3... My W90's have two of them per cab, which I assume is the reason for the 8mfd cap instead of a 4mfd).
I think the second one you mentioned sounds like a 4mfd just like the first one you named. I think mine are CP70 series, but if the CP73 one you mentioned looks the same in terms of the case and overall construction, then you should be okay, but I WOULD try and find two of the same though if you can. The '50's Sangamo caps like mine are US-made and were commonly-used in ham radio gear.
I have direct experience with the W70d and the model 6. I have then both hooked up to my Marantz 2245. The W70D on the inside flanked by the 6's. To be honest the 6's are the newer with the electrolytic caps which I replaced 2 years ago. I also had to source original 12" for them. I have never opened the W70D's because I don't want them out of my rig. I think I will have to this winter due to some distortion that I am picking up. Now about the sound. They are both lovely sounding. The W70D's are so lush sounding. Hearing almost every note, twang of guitar string, and even breathing of the singers. The 6's are nice and clear in their own right. I feel they go higher and lower then the W70D's do how ever they seriously lack in the midrange. I usually run them both together to get the best of both worlds. But when I want to turn up the volume I go to the 6's due to the distortion I hear. I am hoping that it's not clipping that I am hearing but really think it is. Hoping that a recap will get me a little more volume. I till post a pic in a little while.
Always been wondering, how do those early solid-state Fishers sound in comparison to the tube models? In other words, are they tube-like at all? Do they have that musical, engaging sound that harkens back to their '60's tube gear? I imagine the *00T model receivers were voiced in a way similar to the *00B and *00C models, but I was never sure about the early '70's stuff.
Brian said the same thing regarding his alnico W70's and his KLH Sixes. The W70's totally-outmatched them in the mids (There's no denying, vintage Wharfedales easily-belong in the Hall Of Greats when it comes to midrange). I'm listening to my W90's right now, a modern Doyle Bramhall II CD from around 2000, I think, and this is a typical album where these drivers show their stripes. Bramhall is a stickler for those classic, old-school guitar tones, natural overdrives and vintage, transistor-driven effects, and those '60's Wharfedales just tear that s**t up like nothing I've ever heard. It's hard to describe. They nail the TEXTURE of the guitar tones. You DO hear every string. Even the guitars on old mono recordings are like that. You want to hear old mono-era blues guitar done right, that's where you're gonna get it. The sound of fingerstyle blues guitarists, or I should say, those who simply played without a pick, are especially-good. The twangier the better.
That lushness of the W70D's is totally there in earlier models. Like Crestwood23 said, they're just like those old Vox guitar amps from the '60's that the Beatles played. Wharfedale is like a refined, hi-fi version of that, definitely more than any other speaker brand out there, so it's no surprise that they handle vintage British guitar tones so well (Oddly-enough, the late '50's Vox AC15 originally used a Goodmans driver, but I bet the Wharfedale W12/EG would have been more-suitable, had it been introduced earlier (I would love a pair of those... I bet they're amazing with a Vox AC30... Those EL84-based amps have the same lush, bloomy tone as the Wharfedale hi-fi speakers do, so the W12/EG must be a perfect match, being the only 12" guitar driver they ever made back in the '60's).
Listening to "Otis Blue: Otis Sings Soul" at the moment (through my W90's). More mono.
Thanks GT... yes, the caps look like that in your pic... they don't come with any bracket for mounting, guess I can work up some kind of zip tie mount for them... one more question, do you know how tall the legs were on the original speakers... I am going to make a stand with McCobb legs, plywood, and isolation pads to set the speakers on... was thinking either 4" or 6" legs + another 1.75" - 2" for the plywood and isolation, so a 4" leg would get me 6" off the floor, 6" leg would be at 8" off the floor... thoughts on what's the proper height?
