Wharfedale sfb problem
inperson
I just got one wharfedale sfb speaker and when I tested it at my friend's home for a few minutes it played fine but yesterday when I got it hooked up out in my garage it played fine for a few minutes then everything cut out except the tweeter. I was using an old G.E. 6L6 mono amp and had it connected to the 16ohm taps. If I turned the amp off and then after a minute turned it back on the three drivers worked but again after a few minutes they cut out except the tweeter. I tried another tube amp with the same results. Any ideas as to what is causing this?
