wasillaguy
Technician & Fishin'
Picked up a pair of Wahrfedale W-45s that appear to be original. Didn't find a schematic online, so thought I'd post this, along with some questions.
They sound like crap, with thin highs and non-existent low-mid.
I expected the caps to be way out, and they were off (I think the 6ufd was 5.2 on one speaker, the furthest out). I will recap, but don't expect much as I can't see how this crossover ever produced decent sound.
Got out a sig gen and looked at each leg-
Woofer is max at 70Hz, 3dB down @ 350Hz, 6dB down @ 1100Hz
Mid is max at 4900Hz (but only about 2/3 of the input level), 3dB down @ 1840Hz on the low side, and not quite 3dB down all the way up at 20KHz
Tweeter sees nothing until about 13KHz, and never more than about 1/6 the input level, all the way to 20KHz.
If I could get some comments from the gurus-
-What were the designers thinking?
-If I wanted to keep the original drivers, what would you suggest for Xover
-Would it be good practice to keep the low cross down at 350Hz, assuming this was done in consideration of cabinet size?
Thanks in advance!
Thanks in advance!
