soundoc03
Caps are often connected in parallel to achieve a desired spec. For example using a 10uf and a 2uf to equal 12uf. "Cascading" is a high end and expensive way to use ultra quality low value foil caps i.e., 8uf +3uf +1uf to get the best of the highs and lows, but this is really for a more sophisticated speaker and crossover. I used nominal Solens in my 3-way Sherwood Ravinias with good results. At first they may sound shrill but as the caps reform the sound improves markedly. Madisound is a good source for Solens, PE for Daytons. For a higher end cap at a reasonable cost, try NorthCreek Music for their Zens and Harmony caps. George is helpful and has much expertise in these matters.
