Basement
Wharfedale W70s from seller stated circa ~1965 showed up on my local classifieds and I pickeed them up. Apparently these were the seller's father's and overall the cabinets appeared to be in great condition - minus a chip in the leg and small tear out at the rear base of one of the cabinets. The seller briefly demoed them to me and then told me that one speaker was bad. He believes it was the 8" mid and went so far as to include 2 replacements (Chinese non equivalents, I'm not inclined to use them). Given that he apparently fixes speakers himself, this should've been a warning sign that something was not stock.
Regardless I purchased them and today I went ahead and opened the cabinets to do my investigation. Here is what I found:
IMGUR ALBUM (with labels, measurements quick estimate but I could be corrected - not sure what variant I have).
Speaker 1: On listening, no overt abnormalities except maybe mid quieter than I expect.
Opening it up, apparently stock tweeter. Did not open box but shining light shows a tanish colored cone.
8" mid seems to work but seems quiet. I know I should've removed it from the circuit but wanted a quick test; Ohmmeter reads around 20 ohms (in circuit, while music was playing..). Dust cover is somewhat translucent with a screen door effect and cone is black/green. "78" is marked on the magnet.
12" speaker still has Wharfedale frame but surround is foam and a square magnet is labeled "1990" in blue marker.
Speaker 2: On listening, scratchy/intermittent mid.
8" mid has one of the leads to the voice coil with tinsel "patched" with an additional break that I tested with an ohmmeter and seems to remain continuous. 8" doesn't work unless I retract/depress on the cone - then it sounds pretty good and more powerful than that of the other 8". Cone is a lighter green/tan, back side of surround and cone was notably chalky. Dust cover is completely opaque. Again, quick test while everything in circuit; ohmmeter reads 23-30.
12" has a round magnet, labelled made in England, and a cloth surround. Marker says "90". Terminal strip attached to tweeter box is a little janky.
Overall I feel misled as I didn't realize they had been touched so much; I'm not sure what exactly is going on here. My question for all of you is what is stock, what is not, and what needs replacing to get these sounding stock/working? Not even sure where to find some of this or how to approach fixing it...
For reference, $100 got me:
-W70s with stands
-Harman Kardon HD400 CD player with Mariah Carey in the tray
-Harman Kardon CD91 tape deck with pirate Spice Girls
-Denon DRA-545R receiver with the ability to run A+B, remote included
-JVC QL-A200 quartz direct drive turntable with cartridge and a "MR b" stylus - not sure what to replace this with. Thoughts?
->50 records mostly classic rock and the vinyl itself appears to be in good condition. Lots of John Denver/Billy Joel with the additional McCartney, Beatles, but also included some Elvis.
-Dubious wires
-A bottle of Old English
-W70s with stands
-Dubious wires
