Sam08861
Hello All,
Acquired a pair or W70Es and in the process of rehabbing them. All drivers working and the purple dome tweeters (square backs, plactic covers on front) have been replaced with dayton 1" silk dome shielded tweeters. The original tweeters were provided, but one has dome that needs to be glued back and looks like one of the leads to the voice coil is broken. Will deal with that later if the replacements don't sound good.
As is, they sound OK, but the voicing is all off. None of that 'breath of life' I've experienced with the W60D Mk II (should have never sold these) or earlier W70 'a' with all alnico and the super 3 tweeter, though that ported model never sounded quite as good.
The prior owner replaced the crossovers with some generic crossovers from parts express that cross at 800hz and 4000hz, whereas the stock configuration is 600 and 5000hz, effectively squeezing the middle frequency duty from the mid driver.
I am hoping the above is why the voicing is off.
Luckily, the OP left the stock crossovers intact, but either desoldered or completely cut off the leads going to the stock crossover. As a result, I cant tell which driver leads attach where
Anyone with a W70E model have a picture / schematic or other with regard to the connection points?
Glad to post some pictures, if that helps.
