It seems there were a few changes to the W90. I’m rebuilding a pair and working with the crossovers at the moment. My crossovers looks to be different than any others I’ve seen.
The top photo is one I’ve stolen from the net and the bottom is my own. As you can see in the top photo, the single positive wire goes to the middle tap of the inductor which is wired into the mid and tweeter caps. In mine, the single positive wire goes to the outside tap and the positive feeding true mid and tweeter cap are then coming from the center tap.
That means on mine the entire speaker circuit must go through that first bit of inductance. I looked into this because the tweeter don’t should all that “airy”. They seem to have the top end rolled off.
I hope I’m explaining this well, if not please let me know. Here is a very crude drawing of the beginning of the circuit. I left out the pots/L-pads and not sure how to draw an inductor with 3 taps.
As you can see, the positive goes straight into the inductor first and then feeds the driver’s circuits.
Thoughts? Is this a normal circuit? It all looks to be stock solder joints except for where I replaced the caps.
Dan
Dan
