wilberforce
My Beloved Sherwood S-5000II is on strike again--a horrible hum, even I had it recapped less than a year ago. I futzed around swapping the output tubes, but no dice. It's going to the tech tomorrow.
But I had set aside time to do some serious listening. I've got these new speakers that are the best I've ever had. So, I started dragging out the amps.
Just for fun, I hooked up the Lepai T-amp I got from Parts Express for $20 that has sounded pretty good just driving a pair of Minimus 7s out on the patio. Ugh. OK. waddya want for $20? People who describe any T-amp as "tube-like" haven't listened to tubes for a long time.
So rather than give it up for the night, I dragged out my Crown D150A. I recorded and mixed many albums using Crown D150s and DC300s. I thought, THIS will do until I get my tubes back.
NO.
It wasn't much better than the T-amp. In fact, it had less bass. But it lacked the transparency and high end and overall sheen that the Sherwood tubes give. I was surprised. I had imagined that the Crown would at least be CLOSE. No. I tried lifting up the L-pads for more highs on my speakers to compensate, but that didn't get the sound.
Amazing. It was as if all of the magic smoke was let out. Cold, sterile, lifeless. It could be that the Crown is flatter than the Sherwood (I run the Sherwood flat, but who knows if it's flat just because the tone controls are at 12:00?) Maybe it's that synergy thing that we talk about from time to time. Normally, the Crown drives a pair of Yamaha NS10s for the classic 80's LA control room mix sound. Those two sound good together, but the NS10s are notoriously over-bright. It occurred to me that maybe the Crown is analogous to the NS10s. We used to say if you can get a mix sounding good on those, it'll sound good on anything. But when I want to kick back and just glory in the best sound I can get from my system, I don't worry about flat. I'm not going to mix with my horn speakers and a tube amp, that would be crazy. I just wanted to hear some sweet tones, and it was very surprising what a difference an amp makes.
These are the speakers:
http://www.audiokarma.org/forums/showthread.php?t=361690
NO.
It wasn't much better than the T-amp. In fact, it had less bass. But it lacked the transparency and high end and overall sheen that the Sherwood tubes give. I was surprised. I had imagined that the Crown would at least be CLOSE. No. I tried lifting up the L-pads for more highs on my speakers to compensate, but that didn't get the sound.Amazing. It was as if all of the magic smoke was let out. Cold, sterile, lifeless. It could be that the Crown is flatter than the Sherwood (I run the Sherwood flat, but who knows if it's flat just because the tone controls are at 12:00?) Maybe it's that synergy thing that we talk about from time to time. Normally, the Crown drives a pair of Yamaha NS10s for the classic 80's LA control room mix sound. Those two sound good together, but the NS10s are notoriously over-bright. It occurred to me that maybe the Crown is analogous to the NS10s. We used to say if you can get a mix sounding good on those, it'll sound good on anything. But when I want to kick back and just glory in the best sound I can get from my system, I don't worry about flat. I'm not going to mix with my horn speakers and a tube amp, that would be crazy. I just wanted to hear some sweet tones, and it was very surprising what a difference an amp makes.
