ssmith3046
I use Morrow cables ( interconnects, phono, bi-wired speaker ).
Thanks guys, now I'll start shopping around for some cables, or maybe make my own for a change.
If you have a TAPE monitor loop, you can try this little experiment:
Run an RCA IC from the TAPE OUT to the TAPE IN.
Then compare the original signal with the signal that has been passed through the RCA IC by switching the TAPE monitor switch off/on.
Start with cheapest cable you have and listen for any sound degradation when you switch in the TAPE loop.
Chances are you will not need to go any further. OOPS! Did I just say that?![]()
I have Belden tools from my antennae project and was going to buy some more cable and the RCA connectors they sell and make my own.
I found these cables and lost all of my ambition. 15GA, O free, gold plate and dirt cheap. I rewired my entire rack for less than $100. Cables for Less
http://www.cablesforless.com/RCA-Composite-Cables-C12.aspx
For the LaScalas I have some 12 GA O free speaker wire, probably paid too much but I wanted to get them up and running ....haste makes waste.
A lot of the guys on the Klipsch site are using KORD cables, given the low damping rates of the 2205 I may buy some of the 10 GA.
http://www.knukonceptz.com/mobile-audio/speaker-wire/kord-speaker-wire/sp/kord-ultra-flex-10-gauge-speaker-wire/
Here are some pictures of the rack rewire with the cables for less, located in Indy but China contract cables...
http://www.audiokarma.org/forums/showthread.php?t=635158&highlight=Project
I don't mean to derail this thread but what kind of rack is that? I like those cables too.
BJC all the way. Just go these a couple of weeks ago. Two sets of rca interconnects, two digi coax and one for the sub. Interconnect wire is made in USA.
Great stuff at very reasonable prices.
I use only BJC for all my digital connections. Great prices and good quality.
Had had some Mogami and Canare. I ended up pulling all the Canare out because I'm lazy!
The Mogami has the ground/drain/sheath (not sure what it's called) and it is wrapped around the inner wires. Need "X" inches in length? Cut the outer covering, unwrap the drain and you're done.
The Canare instead, has the drain/ground WOVEN around the center stuff and I found myself cursing a bit at the process of un-weaving it.....so dumped it and replaced it with more Mogami.
I have Monster cable 950i on everything...
I make my own cables, Belden with Neutik XLR's and RCA connectors and silver solder....
