Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
While the rubber mat on my 1229 was okay, I prefer a cork mat. Mine is a "Vinyl-Style" mat which runs about $30. Static isn't a problem as I don't have electric heat.
Odd. As I posted earlier, now that it's winter I'm lifting my deerhide mat off the table when I flip sides. And yes I do use a zerostat. Maybe I need to use before dropping the needle and after the side finishes?
I zap before I play - approx. a foot from the record surface. I only use the zero on severe issues; it seems to do ok on my minor static problems (but I do miss the sound of my bare metal platter, however.)
On my Rega P3 I like an acrylic mat in place of the felt mat that created a lot of static problems. On my Dual 1019 I like a 4 mm cork mat I made from a cork tile (cost about $1.00) also helps with VTA (used along with an Aluminati record weight ). On my Lenco L75 I like the original rubber mat, works fine with a Mitchell clamp.
Heavy rubber OEM or hard acrylic are the answers for anti-static in the dry winter, IMO. Tried many, many mats and that's where I finished. Main player heavy rubber, lots of static in the winter but no "cling-lift", hard acrylic on the rest and also no "cling-lift". YMMV.
