What determines speaker volume?
The old EIA standard was for 2.83 V, but at a distance of 40 feet (instead of 1 meter). That's why OLD EV speakers have sensitivities of, say, 42 dB. Don't be misled! :-)
runpaulrun said:
Does speaker impedance have anything to do with this? Does a position on the volume control represent constant power (watts) or constant voltage? In other words, would 4 ohm speakers sound louder than 8 ohm speakers (with the same efficiency) just because they're actually drawing more power (watts) even though the position of the volume control hasn't changed?
Hope this isn't a stupid question. Thanks.
Paul
No, not really. No matter what the impedance the test is done with a 1khz test tone @ 1 watt and then measured at 1 meter.
No, most speakers are a dynamic load, impedance changing with frequency, so its not a "static" state. However,you could call it a constant level.
Yes, because of the "load" 4 ohms presents to the amplifier. In a "perfect" amp, say 100 watts/ch @ 8 ohms, a 4 ohm load should make the amp produce 200 watts, however,this not being a perfect world, that rarely happens.
