Found a pretty good CD-4 copy of Aqualung that has one stubborn problem. At the start of side 2 in maybe the first 10 cycles, there’s a .25” long blob of something. It causes a skip at the very beginning, but if you help it past it plays with background noise until it gets 10 or so turns in and then the sound is great. I’ve put it through the US multiple times, and put alcohol on a cue tip and scrubbed. It cleaned up slightly but the skip and most of the blob are still there.
I have some organic stuff called Superzilla that says you can wipe it on plastics, fiberglass or vinyl siding IF you wipe it off again within a few minutes. Don’t want to kill the LP, just clean it, so not sure if that would be a good idea. Any ideas would be appreciated.
