Hi Everyone, I was wondering if anyone can help me determine if a Conrad Johnson PV9A preamp would be a good match for my Mcintosh MC225? I am new at all this and could use some help. I am worried about matching the components and don't have enough knowledge or experience to make the decision alone. The one thing I keep reading is that there may be a gain issue?? I want to make sure that I have good control of the volume range with sensitive and non-sensitive speakers. I want the flexibility to try many different types, from Magnepans to Harbeth, Klipsch, ZU, and others. Please help I need to pull the trigger soon. Here are the specs of the CJ:
Gain: Phono stage 47dB High level 31dB Output: Maximum 20V Rated at 2.5V Phase:
Line stage inverts phase of all inputs.
Phono overload: in excess of 200 mv at 1KHz Response: bandpass 2Hz to more than 100 KHz RIAA equalization to +/- .25dB (20Hz-20KHz) Hum and noise(20Hz-20KHz): phono inputs: 77dB below 10mv input Line level: 86dB below 2.5V output Distortion: THD less than .25% IM less than .25% Ouput impedance: less than 200 ohms
