My Accuphase has an Inverted Phase button and the unit is from from 2010. Why would such a new unit require this?.
When playing a record with the button off I notice the woofer speaker reverberates and when it is off it doesn't. I also have a 10Hz button which makes no difference.
For the first question- many CD players output in inverted phase, for whatever technical reasons. It's more common than many would think!
For the second question- you're changing the phase between speaker and cartridge. Rumble-feedback from the speaker to the phono cartridge is in-phase in one position (hence, the speaker 'reacts' more to ultra-low frequency feedback, since it's like positive feedback), and is out-of-phase in the other position (the woofer doesn't react nearly as much to ULF feedback, since it's acting as negative feedback- it cancels out, in essence).
As for why the early amps had one-channel phase invert- it was primarily because of the existence, in the early stereo days, of vertically-modulated stereo, vs. horizontally-modulated stereo, on LP records.
Some early stereo records were vertically modulated- the channels were out-of-phase, so the needle would go 'up and down" quite a lot in the groove. This was hard on many stylus/cartridge/arm combinations, so the standardization was made, later to ONLY doing horizontal modulation.
The main difference, is that for vertical modulation, one channel is OUT of phase (in relation to a mono recording). Whereas, with horizontal modulation, they're IN phase, when recorded. So, to play those few vertically-modulated records, you had to invert one channel.
BTW: These vertically-modulated records are also the ones, that say "NOT for playback on MONO systems". You would virtually hear NOTHING from the output, since the information common to the channels, would cause the stylus to go UP and DOWN, whereas mono cartridges read SIDE-to-SIDE. In contrast, horizontally-modulated stereo is OK for mono cartridges- the common information is side-to-side, and ONLY the difference (the things that makes one channel different from the other) are vertical).
But, in short, that's the main reason why we have those single-channel phase-invert switches... for those odd early stereo records, made with the short-lived vertical modulation format...
Regards,
Gordon.
