What is the gain of a Marantz 2270
DomPal
Does anyone know the gain of a 2270 with calculations? I can’t find it on the spec sheet. I try to calculate it based on the rated output at 8 ohm but I get Gain = 100. That can’t be right, right?
Apply a signal say 20mV to the Main In input. Measure the voltage at the outputs. Use the following calculation to obtain gain in dB:
Voltage gain (dB) = 20×log (Audio output voltage / Audio input voltage)
