Yes, you've said that many times, in many threads, as you attempt to sell others on the notion that higher power is not necessary, or that lower power is "better".
Not sure why this bothers you so much...but I for one have reached the point where I'm glad it does.
Power is not "excessive" when it is the proper amount to meet one's requirements. And there is not necessarily a trade-off between power and SQ. Nice try, though
Holy crap, why do you always pick fights and twist words into things that were never said???
It's this simple, if you are trying to recreate the front row of any loud concert, or blasting volume to the limits, more power is a very good idea, probably even a "must have" to prevent exposing speakers to harsh clipping.
If you are
not trying to blast maximum SPL (which most aren't), and have even modestly efficient speakers (which most do), and even a mildly reflective room (which almost all do), you likely do not need more power beyond 30ish WPC. There is nothing ever wrong with getting more power than you need, but unless you like feeding money into a shredder, you probably don't need more power (more likely, that upgrade money would be better spent getting a better quality amp than simply a more powerful amp (
and usually even better spent upgrading speakers or adding a sub rather than changing the amp
For those contemplating getting a more powerful amplifier to get better bass, or better sound quality, out of an existing pair of speakers at normal volume levels -- which is a topic frequently discussed on AK -- I personally think that advising them to get a more powerful amplifier of the same quality level is not a good investment to solve that problem because -- at normal volume levels -- the amp they have isn't being stressed. I say that based upon the principles of how current flow works, which I outlined in a prior post, quoted again below for your convenience. The theory below also correlates with my decades of experience with many amps/receivers.
Prior Post: Looking at it analytically, [higher power amps sounding better at normal volume levels] doesn't seem likely to be the case when you consider that amps don't really "push" current to the speakers. It's tempting to think that a big amp is going to force all this power down to the speakers -- but that's not how it works. The speakers draw current from the amp based upon the apparent impedance they present to the amp at every frequency across the entire frequency spectrum. Any given set of speakers will have the same impedance at every frequency regardless of what amp they are connected to, so -- as long as the amp isn't clipping -- you should get the exact same sound from two different amps when the only difference between them is power output rating.
I want to be clear that I don't discount anyone's experience that a more powerful amp sounded better to them at in-limit volumes -- it could be other differences within the two amps -- and vintage amps vary by sample depending on the health of the internal components. There are many reasons it could sound better independent of maximum power output level. Psychology can also be a factor, though I tend to believe the direct experiences of seasoned audio persons. Whatever the case, the current flow physics make it unlikely that simply increasing power output will improve bass, or any other aspect of the sound, at reasonable volume levels. The design and internal components used in any amp makes more of a sound quality difference than maximum power output (when used at volumes volume levels within operational limits).
I never even remotely suggested that smaller amps sound better than larger amps. That is you twisting words to invent something I never said. Power level and sound quality have no inherent relationship at all. Any differences favoring the sound quality of higher power or lower power amps is due to design differences and internal component choices made by the manufacturer for each brand and model of amp. That said, for any fixed dollar amount, you can buy a higher quality amp by targeting modest power levels than you can if you target only high power amps. Please don't twist this -- that's not me saying small amps are better, that's just basic economics (I know you are still going to twist it anyway).
For the record, the post you quoted is below . I never suggested small amps sound better. In fact, I said pick the higher power amp if everything else is equal. Have fun with your word-twisting invented arguments -- I have zero tolerance for it.
Prior Post: It's a good point. For those that want to recreate that, then more power may well be better -- the "sweet spot" for each person depends on how you use the system. For the minority that push to "front row" concert levels, more power is beneficial.
For those who have no interest recreating the front row, and have reasonably efficient speakers, excessive power is not needed. If you don't want to recreate the front row -- choosing better sound quality in an amp is almost always more important than maximum power output.
If sound quality is the same between two amp options, I'll typically take more power, but beyond 20 or 30wpc, I couldn't care less about power output for how use my system.
