Neither Spectral or Halcro are using VFETs. They are vertical arrays of conventional MOSFETs. Read their literature carefully. Don't think anyone would be making new amps with 25+ year-old devices. But, I have 40 of them (individual VFET devices) and that should be enough for the rest of my life. Too many, in fact. Anyone want a nice, stock B-2?mesut BALCI said:There are vfets currently used for highfrqswithing and also vfet amps like Spectral dma360 and may be the Halcro. But not as good as those. With todays hi-tech, those vfets can easily kill valves. A new market and the money. With power enogh to drive home audio listening. :yes:
He did. I heard him. But a character in Chekhov's Sea Gull pompously mangles two famous Latin epigrams; the marketplace of audio electronics appears sometimes as equally perverse and mangled.Negotiableterms said:I thought Cicero said:
De gustibus, non disputandum est = Of taste, there is no argument.
wualta said:He did. I heard him.
Hee hee. Damn, I sure feel that way these days. My jokes certainly are. Let's hope that the audio market rediscovers triodelike transistors-- which they might, seeing how tubes are coming back-- before I expire from agedness or lose my hearing, whichever comes first.Negotiableterms said:OK, Wualta, you're now officially older than anyone.
wualta said:For home audio this is all too true. Though, if it was MOSFET and not BJT that pushed out VFET, where are all the MOSFET home amps?
But [begins tearing hair out with the madness of it all] MOSFET (or some other form of power FET) is all over car audio. Dominant, even, unless I've been looking at the wrong ads.. De gustibus, my friend, de gustibus aut bene aut nihil..
sanyofreak said:Car Audio "MOSFET" amps by and large do NOT use MOSFETS in any of the audio circuitry, just the Power supply which is commonly known as a DC-DC converter. Their high speed, and low "on" resistance make them pretty much the defacto standard power devices for all switch-mode power supplies (like the DC-DC converters found in most car amps over 25WPC).
the above ends any useful contribution to the thread - read on at Your own risk, and a high ratio of peeing someone off, read on only if You have a thick skin.
When I's a kid, I helped one of my Dad's friends build (yep they were kits) a Hafler D200 amp. While IIRC this was a MOSFET design, and not V-FET. I've come to find out that this is actually a pretty highly thought of design, and of course David, a highly respected audio engineer. ( tell ya what though, that was a pretty complex amp design)
There was nothing not to like about the D200, but little (IMHO) to rave about either, and it did not possess any special audio "magic" that set it apart from any good BJT designs I've ever heard or built. Remember however, I'm NO audiophile, so my input here is meaningless, but after designing and building them for decades, There is just no need for myself, and apparently 99.9% of the other non-audiophiles to use FET's of any kind in an audio amplifier. There's no real gain. And BTW, the D200 was one of the coolest running amps I've ever messed with, period.
You want tube-sound ??? Get a @#$%^ing tube amp, and if I may steal a line from the Malady I participated in the last thread I posted - If Your an "Audiophile", then what do You care If Your amp is bottles, Silicon, Laminated Cat Guts or Pig intestines, If it Sounds good to You ?????
While the economics of it all certainly played a part in the V-FETs demise as stated here, it is certainly the BJT that continues to kill not just FETs, but any other amplifier designs that are out there. Too damn good, too damn cheap.
Lefty said:Ah, but that is the point, an "audiophile" needs their amp to utilize and require something other then what the masses are satified with.....
It does look that way. Then why do you suppose that so relatively few MOSFET amps were put out for home audio? (I only really see Adcom today, and Souncraftmen through the mid 90s.) I had been wondering this lately, given what seems to be a superior dampening ability and the size and weight advantages. What then killed MOSFET in the home audio? (Clearly it won in terms of the limited space in auto applications.)EchoWars said:MOSFET killed VFET.
Nothing has 'killed' the MOSFET for audio applications. First, they aren't used in the audio circuits in auto appliations. So there is no connection there. And there are probably as many MOSFET products as ever, on a percentage basis. Several Nelson Pass amps use them, Sony's last, terrific TOTL ES integrated amps were MOSFET, as was one of their best ES power amps. Unison currently uses in the output stage of their hybrid integrated amp. Halcro amps, which are considered some of the finest in the world, are a vertical array of a type of MOSFET. IIRC, BAT uses MOSFETs in the output stage of all their solid-state power amps and Hitachi's TOTL amps and receivers were also MOSFET, as were the ones from Radio Shack. One problem with all of this is that most manufacturers do not advertise what output device they use. They generally don't want you to know more than they have to tell you. Because if you know then their competitors will also know.sydsfloyd67 said:It does look that way. Then why do you suppose that so relatively few MOSFET amps were put out for home audio? (I only really see Adcom today, and Souncraftmen through the mid 90s.) I had been wondering this lately, given what seems to be a superior dampening ability and the size and weight advantages. What then killed MOSFET in the home audio? (Clearly it won in terms of the limited space in auto applications.)
Yamaha B-2 said:It does surprise me that more folks don't use MOSFETs, as with current process tools they are a superior device from a noise stand-point.
Y.B, Thanks for the examples, I didn't realize there were so many out there for sale. Those claiming the application are indeed just a small portion of the market. As far as car audio, I must say I hear a distinct sound from "MOSFET" head units like my '05 Pioneer dash unit that is quite distinct from any of the vintage receiver listening I've done. Soundcraftsmen MOSFET output does remind me of this difference, as does the T-amp sound (also Class D). -sfYamaha B-2 said:Nothing has 'killed' the MOSFET for audio applications. First, they aren't used in the audio circuits in auto appliations. So there is no connection there.......It does surprise me that more folks don't use MOSFETs, as with current process tools they are a superior device from a noise stand-point.
