One might consider used also? It could get you more for your money spent. I'm never heard much in the way that decent built phono stages are that prone to failure.
Usually, the more adjustability they have, the more they cost. And adjustability is a good thing, because one day you may find a need for another Cartridge, and possibly a certain phono stage won't be quite compatible with gain and loading settings.
Not sure about the Sutherland marketing comments to say anything about such, but Sutherland makes some very good phono stages, made in USA, a good company, and I myself own an older Sutherland PHD, great unit, been very happy with it. I would highly recommend the PHD, you might be able to find one today at the $1000 price. Gain is 45-50-55-60db and loading is 100, 200, 1000 and 47K ohms with the supplied stock Boards. Both Boards simply unplug from the Mother Board, and rotate into place for the different settings for gain-loading.
Battery Powered, free from EMI and RFI nasties. A dead quiet unit, auto-on and off sentry, auto on is adjustable via a screw type Pot on the Board, and Batteries last about 800 hours of play.
There is a low battery Sentry monitor and light on the front of the unit, plus on, and right before going to sleep. Uses 16 D-Cells. A heavy unit at 29 lbs, beautiful construction.
Generally, the stock boards can usually handle quite many MC Cartridges, and as well MM.
Their was once a high gain board available, 62-64-66-68db, and a blank loading board were resistors could be soldered to the board giving any loading one would choose. Probably again giving 4 choices of custom loading if needed.
Their internal layouts are quite clean, uncluttered on the Sutherland Units.
There are so many to choose from, and I know, this is what makes choosing hard in virtually any price range. Tubes can offer a lush midrange, but can also exibit what is referred to as tube rush. And then there's the tube rolling, and replacement involved possibly which can add to costs over time.
Some are simpler designs, maybe the use of 1 or 2 tubes, others a bit more elaborate, and more tubes.
Phono stages like the Manley Steelhead and Asthetix Rhea (sp) come to mind as 2.
Here's a PHD currently listed.for reference and pics.
https://www.ebay.com/itm/SUTHERLAND...675203?hash=item4b8b6c42c3:g:r4EAAOSwNCRgC4UG
