What should I build next?
Redboy
a few good watts
It's official - I'm hooked! DIY is what really turns my crank these days. First the Angela SET 2A3, then the Olson clone, which is nearly dialed in. I'm thinking about the next project, and I'm wide open to suggestions.
Some criteria:
  • It should have a practical application in my system.
  • It should be fairly simple, but with a detailed schematic. I'm not to the point where I can do this by intuition.
  • Tubes are always good.
  • It should be reasonably inexpensive, using reasonably attainable parts.
  • Point to point preferred.
I'd like to build on a 1 sq.ft. aluminum plate, like I've used in my other projects. I was kicking around the idea of a simple preamp, and ejfud suggested the grounded grid pre.
Do you do vinyl? If so, a nice phono preamp would be a challenging project. Simple in concept and low in parts count, but challenging in getting it quiet.
The classic RCA RIAA circuit is good sounding and any RCA Receiving Tubes manual has the scoop on it.
Of course, a preamp would be value-added for you! I have Rosenblits' book, which IIRC has all the scoop on that design (which, of course, you can also buy as a kit -- but I guess you're past that!).
Have you perused the projects on Gary Kaufman's page?
www.the-planet.org
specifically (maybe):
http://www.the-planet.org/linestage2.html
http://www.the-planet.org/6S4.html
http://www.the-planet.org/Shishido.html
The phono pre is probably something for a little later down the road. I've got only a very small, crappy selection of vinyl at the moment.
I do like the idea of building a linestage preamp, and that probably makes the most sense for me at this juncture. Your buddy Gary's got some intriguing plans there, and they look fairly straightforward.
How about this idea of the grounded grid pre? I have yet to see a decent schematic for one, but the local fellas seem excited about the idea.
I probably just need someone to tell me what to build.
You could always build a tube based active crossover for your Fortes and put both your DIY amps to use.
Just change the caps and resistors to match your frequency needs and stack them if you want to clone the expensive Marchand tube XOs.
Speakerlust said:
I think you should build a pair of these and hook them L and R channels ....
Cool, a very basic plasma speaker. That approach could make for some very interesting sounds in original performances.
- JP
Aikido linestage?
I've been reading a lot of good things about the Aikido linestage and the very reasonably priced amplifier stage boards and partial kits available kind of make it more of a sure thing than venturing into scratch building with a circuit drawing.
I've mulled over various DIY options for a line-stage myself and pretty much had it down to either an Aikido, Electra-Print Ultrapath or something out of Sound Practices like the Berman 76 but a personal reality check talked me out of it. I really have limited time to put into DIY these days and figured it best to apply that elsewhere while buying a top tier pre-amp used that can be a 'known quantity' and have decent re-sale value if I'm not completely happy (not much more money wise than I was planning on spending either).
I scratch built aikido's in mono with parts on hand and another 30 bucks in parts.
They work rather well with my 2A3 SET amp, but I don't really need that much input voltage/gain. I can get rather loud with just a 100K pot between the source and the amp.
They work best and the most quiet with my Admiral and Magnavox 6BQ5 PP amps.
The input stage 6SN7 is sensitive to microphonics, so I had to sort through a bunch to find one that didn't clang and bang or scream.
I had a pair a Electra-print line stage OPT's for a Ultra-Path pre-amp project once. But got broke and flogged them.
These particular samples of line-stage output transformers didn't measure very well on the bench with respect to bandwidth, IIRC.
I still eventually want to cobble up a 12B4A linestage one of these days.......
Bill, that's an interesting point (and a good one!) about weighing out the cost benefits of building from scratch vs. buying a good used pre. I'll have to take that into consideration.
And Mike, you've got me thinking with that comment about not really needing the gain with your 2A3 amp. I remember reading something to that effect earlier, that the 100K stereo pot alone is a viable option for that circuit. And it seems to be. Could it be the preferred option? What do I stand to gain from having a preamp in the path rather than the 100K pot as I do now?
This post gave me an idea for your next project. How about a "real" volume control. :yes: http://www.intactaudio.com/atten.html
FWIW, I don't run a pre on my 2A3s either.:no:
www.hagtech.com has some neat stuff.
I am going to build a Ripper which is an analog to USB converter. It also works the other way around as a D/A converter.
Its not point to point, its not tubes, and it costs around 200 bucks if you build it yourself.
Not sure if this is up your alley, just throwing that out there.
I have all my music ripped to WMA lossless on my computer.
Evan
It has been said that often times preamplifiers act as input impedance matchers between equipment. I still have a NOS pair of 12b4s, never got around to the linestage.
Evan
if I were you I'd build a mu-stage with a pentode CF at the top, as seen in Figure 4 around 1/4 down the page. you'd need some help with specific values but I'd try the 5687 for gain, maybe the 12B4 if you don't want quite as much. The 6JK6, 6JL6, 6JT8, 6LB8, 6LQ8, 6HL5, 6KR8, 6KV8 or 6LY8 all seem like they would work as the pentode section. If they're triode-pentodes, just ignore the triode part :)
I like the Aikido a lot. I have built a couple of Aikido’s one scratch built and with Bas Horneman’s, boards. I even ordered the partial kit from Tube cad when it was $99.
I have a spare set of Bas’s octal boards if you want to trade…John
