ignoramustot
Hello again Sansui brains trust
An occasional temptation of mine (when not enjoying the sweet sounds of my recently recapped and upgraded AU-555A) is to keep an eye open for an opportunity to upgrade from my trusty AU-4900 to an AU-6900 or AU-7900, if I can find a good one that is not too expensive (hah!
).. (And before anyone asks, the AU-5900 doesn't seem to offer enough above an AU-4900 to make the switch.)
I notice that the AU-6600 and AU-7700 seem very similar in design and features to their corresponding models in following series, AU-6900 and AU-7900, albeit with slightly better performance specs quoted when new for the later models (higher RMS wattage; lower distortion; etc.).
Are there any significant differences or improvements in the latter AU-x900 models that make them worth waiting for or pursuing over their equivalent siblings from the immediately preceding generation?
For example, and with reference to the recent entertaining parallel discussion in this forum about Sansui heat sinks, I notice the rear heatsinks on the AU-6900/7900 appear a bit more substantial or exposed than those on the AU-6600/7700. Does that have much significant difference on reliability?
e.g. compare http://www.sansui.us/images/AU7700_Series/au6600_6.jpg with http://www.sansui.us/images/AU7900_Series/au6900_2.jpg
(And being conscious to rate physical condition of the amp and known history of the seller as more important determinants when choosing between comparable available amps, in most cases...)
Thanks,
Rob
Thanks,
Rob
