I recently picked up a pair of output transformers from a H/K TA-260... 4K CT, with 4, 8 and 16 ohm secondaries. This model used 7355s and was probably in the 30W/ch ballpark.
One option would be to make an EL34 amp out of them.
But I also have a bunch of 6080s, and was thinking that since they're dual triodes, a single-bottle-per-channel push-pull amplifier might be fun. I drew up an AB1 operating point that has 230V across the tube and biases at about -130V. Because the data sheet recommends not using fixed bias, I'd want probably a 370V B+ rail (to get 360V to the plates, after resistive losses in the OT), and then a 3K 10W resistor on each cathode. I think I could get 15W/ch (conservatively) out of that, but I'm mildly concerned about using cathode bias with an AB1 output stage (and the bias shift that would occur in the Class B portion of the load line).
Needs a lot of driving voltage, but a Mullard 5-20 type front end using 12AX7s should be up to the task -- the 6080 can easily handle a 470K grid circuit resistance (1M ohm is listed as the max in the data sheet).
Anybody here built a 6080 output stage?
