WannaBeHiFi
I read an article once that left me rather impressed by the quality that went into the M series amps back in the day. Yamaha kinda had a chip on their shoulder and wanted to make a point.
Eventually I acquired a M-45 in quite good condition. But as I learned more about vintage equipment it became apparent that the nearly 40 year old electrolytic caps are way past their expiration date. Well, If I'm gonna rebuild the M-45 I have to have something to listen to.... Which brings me to this discussion. Since I now have something to compare the M-45 to.
What I had: GR Research X-LS Encore speakers. M-45, C-85, Phono, Bluetooth from I Phone or PC. But I was not happy with the sound. I was not hearing the soundstage imaging I had hope to when I built the speakers. I knew BT was part of the problem, I suspected the M-45.
The C-85 died. For a while I just ran the BT direct into the M-45 and backed the gain way down. Which made me rethink the whole concept of what a pre-amp actually does. Though I do miss the Yamaha variable loudness.
Change 1: I replaced BT with a WIIM mini streamer. < $100 Noticeable improvement.
Change 2: I added a SMSL SU-1 DAC. < $100 Noticeable improvement.
Change 3: I replaced the M-45 with a Aiyima A07 Max amplifier. < $100 Noticeable improvement. Now I'm hearing a bit of a sound stage. Keep in mind my room or speaker placement hasn't changed. What I lost was, bass response. The M-45 delivers bass with an authority that the Aiyima lacks.
I've been listening to that for the better part of a year.
Change 4: Recently, I replaced the stock op amps on the Aiyima with Sparkos. $150 WOW! Noticeable improvement. Now I've got sound stage detail I've never heard before!
Example: David Grissman Kaleidoscope F5. I've never heard so clearly defined in space two mandolins, Dawg on the R, support L. Two violins, Lead on L, support on R. A very sweet guitar right in the middle, with a bass behind the guitar.
I gotta whole bunch of music I gotta relisten to. How exciting!
Here is my dilemma. An inexpensive chifi amp sounds better than my nearly 40 year old M-45.
Now the signal from the Streamer>DAC> amp did not change. The Aiyima already sounded better than the M. THEN the Sparkos op amps extracted more resolution and detail from that signal.
Since my only listening experience is with an OLD M-45. How might a re-capped M-45 sound with that same input? How much of that resolution and detail that he Sparkos revealed might one expect a restored M-45 to deliver? Will a restored M-45 deliver that layered soundstage that the Sparkos upgraded A07 has exposed? Is the recap worth it?
