This, sort of, is meant to be a extension of the now closed "is audio quality desirable".
I thought there was some interesting takes for sure, in between the other stuff.
Do you prefer a more revealing playback system, smoother/musical, or some where in between?
And if, and how your playback system has involved, for what ever reason, different formats, sources etc. HD/lossless……..whatever.....exclusive to certain playback formats etc..
I'm using these terms as generalizations. I think most here having and idea what I mean, with out fine labeling/etc.
My two systems has involved into what I consider the perfect compromise for my modded AMT3's-sporting the Great Heils. In a nut shell those mods mainly concerned getting the bass on par with the Great Heil-it worked better then I imagined-these things rock!. The level of bass detail-frankly is one of the best I can recall hearing. Clearly on par with the Heil.
Lots of work-with a equal share of luck....
But the Heil can be very revealing in the highs. mids, so I tried to evolve into a system, that takes the edge off a bit, without killing the detail, speed and rhythm. Easier said then done, but for the most part it works well. And with a few minor adjustments I can easily switch to a more revealing system.
A careful mix of tube front end, vintage style DAC's, robust power supply fast slew, amplification, mild spatial, and bass adjustments-no electronic crossovers, mini DSP, pc programs etc-a Fox SS-X does the lion's share when needed.
Have not ventured into lossless-but I imagine I will at some point. I have so many different sources of cool material, it's not a high priority.
My system isn't state of the art, but it's a 'work of art' in its own right, a means to a ends, with lots of trial and error over the years-but lot's of knowledge and understanding gained over those years....kinda paralleling my own life in many ways...….
