Hello Folks, I'll thank some advice on value. I just had updated and modded a set of Polk SDA SRS / Parasound P/LD-2000 / Parasound HCA 2200 MKI (sorry for Typo in header, it's a MKI and not a MKII). Work on all of them was performed by Ed Brown, well known here in the forums, taking them to their max potential sparing no reasonable cost in parts and labor.
The SDA's
- New cabinet tops, bottoms and side strips in solid Mahogany
- Cabinet was sealed
- Black Hole 5 applied
- Soundcoat on speaker baskets
- Crossovers upgraded to Sonicap Capacitors and Mills Resistors
- All internal wire DH Labs
- All driver hardware changed, installed hurricane nuts
- New binding posts
- Upgraded XLR interconnect DH Labs cable
- Replaced 1 driver
- All tweeters upgraded
- All driver magnets epoxied
- New acoustic transparent fabric
Amp HCA 2200 MKI Upgraded
- Sonicaps capacitors
- Power supply caps
- Op-amps
- Mills resistors
- Thermal insulators
Pre-Amp
- Power supply
- Film & Electrolytic capacitors
- Vishay Resistors
What would be a reasonable value for these components in the current state? Thanks!
The SDA's
- New binding posts
- Replaced 1 driver
- Power supply caps
- Op-amps
- Mills resistors
Pre-Amp
- Power supply
- Vishay Resistors
