Don,
You know I have the greatest of respect for your opinions. So, for me to offer anything that may 'appear' as 'contrary' is almost painful for me. But, in the interest of 'discussion only'.....I've had almost the exact opposite experience with my 'testing' in my 2 Fisher 500Cs, the one 500B, and the 800. For me, it was the output tubes making almost all the difference, with the pre-amp tubes making little to no discernible difference. Because the units take so many 12AX7s to be functional......I ordered 30 of the Chinese 12AXs from CEDist. I then did a LOT of rolling between amps.....including the use of the old Teles, some British Mullard and Ampex tube.....and of course, some old US types. In the end, I was hearing a more 'brittle' or 'harsh' sound from use of JJ outputs, less so with the EH, and essentially NONE of that condition from old US 7591s. The 12AXs seemed to make little difference during my testing. HOWEVER, I will also note that ALL 12AXs used were either VG if old......or were NEW versions of the Cino tubes. Honestly.......I was not only surprised....but somewhat delighted. I then turned to putting some of these Chinese tubes into the integrated amps I had and I found similar results. To me, this may reflect a change for the good in the Chinese 12AX7s.......as a decade ago I would not have even attempted this test due to the poor quality of these tubes. Further, I'm a dyed-in-the-wool patriot......and use of NON-US stuff is REALLY difficult for me on general principle. But, sometimes 'economics' necessitates compromise......so I gave these things a try.....and with very satisfactory results. Now, one comment would be that of the 30 I've ordered, 3 have failed due to cracks in the glass by the pins. So, figure that into the mix. CE replaced these at NC to me......but still....that's a 10% failure ratio....which is HORRIBLE by most any production standard! But, still, figuring the cost/tube vs projected acquisition cost of 30 US or Euro tubes, and then consider the performance to be 'ok' at worst......and it becomes rather compelling. Anyway......if Rob decides to make it over here.....I'll let him do some rolling as well and see if he agrees. Tom D.
