KentTeffeteller
Gimpus Stereophilus!
That RFI is something I've been warned about. Evidently one rather sacrifices radio function as a trade-off for having better sound in the pre-recorded function (USB Drive). Most HD posts on the subject have echoed the sentiment of some amps being worse than others. Supposedly the 'Stinger' amp is one of the best for NOT causing the radio to be worthless. Of the 5 amps I listed up in Post #14, the Stinger is the only one that has received any 'favorable' commentary regarding this RFI problem. As such, it may end up being the selection I make. However, I've had REALLY good results with JL stuff in the past...... going WAY back into early auto-audio history. There's also a Kicker amp that's in the running, and it too has history with me and past systems from years ago. I know both Kicker and JL have been around for a LONG time.....and I know nothing about Stinger, mmats, or Hertz (or the others). So....tough decision. Fortunately, I've got you guys to help guide me.
Is there any way to effectively shield the amp's RFI from being so invasive? Also, is this an 'emission' type RFI coming right out of the amp itself, or is this conducted on the power lines? One comment on the HD forum was to keep the amp as far away from the FM antenna lead as possible. If it's an emission RFI and making it's way into the antenna lead, what about doing something 'old school' like wrapping the antenna wire in tin foil......or something creative like that? I presume wrapping the amp would be an invitation for an thermal failure of some kind.
That RFI is not just affecting radio reception either. It's also injecting noise into gain stages, and another thing to cause hum issues. And affect sound quality thusly. A lot of SMPS units are not very well designed nor filtered against this junk.
