what's this red square with a P?
john alex
When I turn on my GX40ES Sony amplifier--into which AM/FM tuner, CD player, Tape Player and Phono are connected--a small red square with the letter P appears and everything stops. If I turn the unit on and off a few
times it goes away. Can anyone help?
Protect
The P likely stands for protection. You have an internal short or problem and the amp is not going into play mode in order to avoid problems.
time for some troubleeshooting. Is everything connected correctly? check your manual if you have one.
yep, that's a bad sign. Chances are it will get worse, and not come up after the "perma-P".
Well, right now it's unknown why is it going into protection. If it's for real safe operation issues, you'll want to correct that as soon as possible. Having a situation that's really trying to activate the protection circuit to save itself, might be stressing the amp.
If there's too much output current, the amplifier can be damaged. If there's a DC instability, the protection will react. You might hear a 'pop' when it goes into 'P' mode.
Look at the recommended hook-up and operation in the manual and know the condition (impedance, functionality) of your speakers.
If there's still a problem, (either) bring it to a shop, or delve.
Delving is not that easy, and the more you know, the easier the job gets.
Chasing down unstable DC operation can be very tricky, especially within a feedback loop.
SONY GX40ES receiver
Happy to say I've solved the problem.
I found the manual and under troubleshooting read that the Impedence
had to be properly coordinated with the speakers. It wasn't. I easily
switched it with a screwdriver (little slot on back above speaker connections).
No more flickering square with P! Plays great.
Great Christmas present!
John Alex
