streckfu
Slow on the uptake.
Backstory:
As described in my bookshelf speaker thread, I picked up the Overnight Sensation speaker kit to build and put them together. I tested the crossovers with the drivers out of the enclosures after building them with a small Kinter amp I have. They seemed to work fine so I put them in the cabinets and went to test them using the SX-680 in my son's room.
Immediately upon power up the left channel meter spiked and a second later went to zero....blown channel fuse. After making certain that I connected the speakers correctly, and hoping that it was just a short in the speaker, I removed the OSs and connected the previous speakers then replaced the fuse. No change with no output on the left channel while the right is just fine. And to add icing to the cake, the woofer driver is seized.....
I have the service manual and will start investigating this weekend.
I am hoping (but it doesn't look good) that the STK0039 is not fried. In case I need a new STK, is Ebay still the only source? I am not finding anything via Google searches that are not Ebay auctions.
Should I check anything before moving the good STK0039 to the other position to verify the left one is bad? I am hesitant to do that out of fear of damaging it as well...If I need to replace the STK, which thermal grease/paste should I use? Will something like this work: LINK
Any advice in how to proceed is appreciated.
