When Will I Learn?
UncleAng
First Love.... Marantz!
Some of you may recall that a few years ago I purchased a new Rega Planar 3 only to sell it a month later after I refurbished my Heybrook TT2 TT while the Rega was breaking in its Ania cart.
That cost me $500.
Well, it's happened again.
My Nakamichi CA-7A pre-amp has a well documented problem where the balance control loses contact with a channel; either left or right when in the center position.
My pre- amp was built in 1990 and this problem first appeared when it was 20 years old. I had it serviced last in 2021, but the problem is back now, and has been for the past 6 months.
Realizing that this is a recurring problem that requires a part that is unobtanium I decided to buy a NAD C-165BEE pre-amp... a 6 year old used one for $700.
It has decent reviews and, technology wise, it has some newer tweaks, so it should do the job.
So, once installed the only change to my system is the pre-amp, everything else is the same.
After letting it warm up playing Christmas CD's for several hours I decided to sit down and do some serious listening.
It sounds pretty good, upper midrange is a bit more forward, not a bad thing, treble is very good but the bass did not appear to be as tight and well defined as the NAK.
So I put the Titanic CD in a tray, my go to bass tester, and sure enough my initial impressions were right.
Don't get me wrong, it has very good bass, just not in the same league as the NAK.
The NAD has an MM/MC section with 3 load adjustments for MC carts (50,100,600 ohm).
My MC cart is compatible with 100 ohms.
Using the 100 ohm setting the dynamics were simply missing, moving up to 600 ohms helped a lot dynamics wise, but it's nowhere near as detailed or transparent as in the NAK at 100 ohms.
Major letdown here.
Buying a separate phono stage would not help here as it would be going through the line stage on the pre-amp which is not as good as the NAK's. waste of more money.
Let's talk about my NAK pre-amp. It has two toroidal transformers with separate windings for each channel. One transformer is for the line stage and the other one is dedicated to the MM/MC circuit. It only has four electrolytic capacitors - two for each power supply; no other caps in any circuits.
Lastly it also has three different 'offset adjustments' to address wear over time; one for MC, one for MM, and lastly one for the Line circuit.
When comparing the NAD to the NAK it's not apples to apples, but I knew that.
I dropped off the NAK to my service tech this morning for servicing; he will also reset the offset adjustments while he's at it.
One other thing, the NAK pre has 1 K ohm output resistance (and the NAK amp is at 50 K input), however the NAD is at only 75 ohms.
The ratio of the NAK amp to the NAD pre is 666:1.
This setup requires 35% more volume from the NAD pre to equal the volume on the NAK pre.
I don't know if this affects the SQ of the NAD?
Final thoughts; it appears that I will fix the NAK pre and sell the NAD pre in due course.
