Where to find replacemtn for this power switch?
fdejong
AK Subscriber
Hi Folks
I have a cool Kenwood KC-6060A here, but it needs a power switch replacement and unfortunately I don't have the old part to know exactly what I need.
I found a pretty good replacement from a Pioneer tuner, but it's not an exact fit.
Does anyone know if I can buy this kind of switch new at a parts house like digikey or mcm? If so, what are they called? flip lever switch?
The one pictured is almost right, except I need one with mounting holes above and below the switch (vs right and left) and it's a touch wide.
Hi Folks
I don't know, but when you find a source, you might want to spring for two, just in case you have another failure. I have two Hafler DH-200 power amps and when a switch went out many years ago, I managed to find a source and bought three, as the amp was long since discontinued and the company is now also gone.
Otto
I do not know of any modern parts mfgr. that is making that style of switch. The Pioneer switch you have is for a (relatively) high-powered piece. The 6060A does not require such a heavy-duty unit. I'd be looking for a switch from a Kenwood tuner or low-powered receiver of about the same time period.
Can you open it and rebuild from similar switches?
Did that for an old Alps power switch for my Luxman.
Yup, out of a SX-828 or something like that.
Bummed there isn't a supplier out there for these, but good suggestion. I think I can probably find one from an old broken tuner.
Have you tried doing a search using the part number on the switch? the original manufacture might not be out there but you never know someone might make a clone. I wouldn't doubt the part number of that switch is cross referenced with another switch or two.
If you live in a place with a electronics wholesale house you might want to take it in there and ask them if they can find a replacement.
You might get lucky ... might win the Super Ball too ...
Maybe easier to just leave the original switch in the case and bypass it, then add a remote control to turn it on or off ...
Step up from a Clapper! :D
You dont have the old switch, if you did you could most likely repair it by opening it up. Probably a dirty contact or such, pry back the sheet metal tabs and look. Unless a spring is broke, or a plastic part of a detent is damaged most things can be fixed (assuming its not burnt up)
Something like this one maybe?
Hole centers are 1-3/8", width ~5/8" body to 11/16" over rivet.
SME TV-5, Snap switch, Issue L615
Probably McMaster-Carr or Grainger......
If the front panel behind the faceplate has the room (trim the 1/2 moons off the switch mount ends) drill holes in the panel to accomodate the switch.
