Where to get Custom enclosure for tube amps?
Mrsimo
Hi, I’ve been attempting to build my own aluminium enclosures for two mono tubes amps. It’s not going great haha
Has anyone gone down the route of a custom enclosure built by a company?
Just wondered who you used and an idea of cost?
Thanks
Not having to look for one or build one for myself, I think you might just have to go to swap meets or electronics shows, or maybe someone else here could give you some clues. :thumbsup:
Good luck! :music:
Satisfied customer, no affiliation. https://www.landfallsystems.com/
I've since moved to Hammond aluminum chassis but they are are too thin. I cut out the top and use it as a bottom (leaving the corners for feet) and then get some 2 ~ 3mm aluminum to screw against the original bottom using JB Weld and some 3mm countersunk screw/nuts as a new top.
Then use two small U-shaped pieces of aluminum for fastening a protective bottom with airgaps.
Some pictures to show what I mean - don't look at the wiring mess, that was temporary to test things out before making a more permanent and tidy construction.
Thanks for the link. So from that I’d be looking roughly at around £100 per box. Been trying to find a Chinese company that I might be able to use as it would likely be cheaper and I don’t mind waiting.
