Where to get Technics parts? Need motor.
cal_tyke
Member
Does anyone out there have a good source for Technics parts?
I need a new motor, or motor assembly (circuit board has some components on it as well as the motor) for an SL-B303.
I have the service manual, and I did a web search for the part number. The two parts companies I dug up both listed the part number as out of production.
Any ideas, other than waiting for one to come up on eBay?
Thanks for any suggestions.
It's likely that if you were able to find a new motor it would cost more than the turntable is worth. But in your search for junkers also keep your eyes open for the SL-B202 and B101 as they used the same motor.
Also, if you like particularly like this model keep your eyes open for an SL-D303 or an SL-Q303 (direct drive and dd quartz) as a replacement. Same basic design, but better speed stability, and they usually can be had for as much as a new motor. Then just hold onto the B303 for extra common parts for the new table.
Thanks for the replies. Like many AK folks, I have a few turntables (is there a cure?).This Technics is the most basic I have, and I picked it up quite cheaply. I was hoping to fix it for my younger daughter to use. My 8yo has an SL-1900 which I fixed, and her younger sister says she would now love a turntable too!
I hoped that somewhere out there I could find a Technics parts stockist, but if I can't then I'll probably offer it for parts myself.
Cheers.
What's the problem with the motor? I've had Technics belt drive tables that operated erratically speed-wise that just needed the switches and pots cleaned really well.
Thanks - I'll check again and see if I can locate the Technics parts store on eBay.
Regarding the motor problem - it is mechanically noisy, sounds like there is some friction inside, perhaps some misalignment, broken bearing etc.? Also, I have speed instability too, especially at 45rpm - but I've fixed this with other t/tables by cleaning pots and I planned to do this as a second stage. Perhaps I'll fix that part today.
