Very excited to have these, and trying to figure out which version they are. They seem to have low-ish serial numbers (1440 and 1596). One woofer is the half rolled damped fabric (?) and the other has a foam surround. Both PRs have foam surrounds. (All the foam looks to be in great shape, thankfully!) The Heils are silver, not black.
I'm referencing a helpful post from a while back, and it makes me suspect that these are early, original build Monitors with later-replaced PRs and one woofer? Problem is, I don't see that they ever came with PRs that had bextrene cones and open cell foam surrounds.
Reason I want to know is that I'd like to get a woofer to make a matched pair, so I'm trying to figure out which woofer is the correct woofer for the particular revision.
Thanks in advance for any help. Haven't listened to them beyond verifying that the tweeters work, very excited that they both work.
I guess it goes without saying that when the crossover says AMT MONITOR that one would surmise they are AMT MONITORS.
Not trying to be the fly in the ointment but hey...
Four unpublished revisions took place on those AMT MONITORS. None of these four were labeled anything other than, AMT MONITOR.
Early versions were with silver AMT units, metalized capacitor films, bextrene woofer cones w/ open cell foam surrounds, and .75in styrene disc radiators on the aluminum rings w/ the same suspension.
1st mid-build revisions came with flat black AMT units, bextrene woofer cones w/ rolled-edge treated surrounds, and .5in styrene discs w/ open cell foam suspension.
2nd mid-build revisions incorporate a huge change to the radiator, they were made to reflect the same outer rolled-edge suspension of the bextrene woofer and updated to a conical bextrene passive. When this radiator was introduced, it attached to an entire cast woofer frame (less the magnet and motor structure) obviously. The inner coil area behind the dual dustcaps was sealed up with an inverted pulp disc.
Final build revision on the AMT MONITOR came circa 1979 when they utilized the SBR (styrene butadiene rubber) half-roll suspension on both the bextrene woofer and conical bextrene radiator. This final build was in production during the outphasing of the 1B towers hence the SBR suspension changeover, which the 1C line of towers took on exclusively.
