Ishmael
I have been looking for the integrated amplifier the Hitachi FT-920 tuner was meant to partner with but can't seem to find a match. Here's what I have found out so far.
1. The FT-920 tuner was made in 1977.
2. From Hifiengine the Hitachi HA-610 (70 watts 8 ohm) was made in 1975, the Hitachi HA-1100 (100 watts 8 ohm) was made in 1976, and the Hitachi HA-330 (40 watts 8 ohm) was made in 1977.
3. None of the above integrated amplifiers appear on Hifiengine with a wood enclosure, however the FT-920 does have a wood enclosure.
4. The much earlier Hitachi IA-1000 (55 watts 8 ohm) made in 1971 does have lovely wood side panels.
From what I have been able to find on the web it looks like the FT-920 is a stand alone tuner without a partnering integrated/seperates amp-preamp? If this is true even though it is an earlier integrated amplifier would the IA-1000 be a better match given the wood case, or, should I consider one of the more contemporary amplifiers listed above? All our current vintage speakers are 8 ohm so power is likely not an issue from any of the amplifiers listed above. Thanks for any help you can provide.
