Kingpin5
Lunatic Member
Hello Friends,
I’m perplexed or struggling with choices. I have a small listening room ~15 ft x 20 ft. (5 m x 7 m approximately). I’ve got three active turntables, a Dual 1229, a Dual 1219 and a Thorens TD-165. All three function in perfect order and run beautifully. The Duals feed into a Marantz 3200 Stereo Console and then fed through a Marantz 2230b receiver powering a set of DCM TF-400s. The 165 is fed into a HK 930 and it drives some baby Advents. So far I’m not hurting for options to play a slab of wax.
However, I’ve a serious case of upgraditis and the green light from management to move forward.
My the choices are:
1) New cartridges and styli for the three decks. ( 78 rpm- 33 1/3 stereo- 33 1/3 mono), this is easy and completely doable. By doing this I can also dip a toe into three.
2) A Thorens TD-125. (MK I or MK II) refresh/restored by a certain well known Thorens engineer. The case would be where I buy a functioning 125 and have it overhauled. The most expensive choice, which then negates my ability to do choices one or three for a while.
3) Buy almost every grail I can off a certain well known website. This one at this point is the most logical. I like my setup. I cannot spend enough time with it, but I love hunting for records. If I do this, what do I do later on when I’m casting about what to do with some sudden free time?
These are first world problems I’m faced with here.
What is anyone else thinking?
My the choices are:
