Which speakers (vintage & new) would you pear with a Marantz 1060 or 2230?
jazzboombap
So my current setup is that I purchased a Technics SL-1200, threw on the audiophile Cartridge Audio-Technica AT120EB. I am in the process of purchasing a Marantz 1060 so I'm wondering now... what would I need speaker wise vintage and/or new to really have a nice audiophile setup. Any suggestions would be welcome and would be appreciated!!!
-Brian from the SF Bay Area
Need more info.
Budget.
Size of room.
Style of music.
Desired volume levels.
Floor stander or bookshelf.
etc...
Marantz 1060 is rated at 30 wpc for those who have suggestions.
Vintage
JBL.....
And what @goodolpg said ^^
Need more info.
I gave my 2230 to my daughter and son-in-law, along with my ESS amt Monitors. The 30 watts drives two 14"woofers (one active, one passive per cabinet) and Heil air motion transformers easily to volumes that will run you out of the room. Any reasonably efficient speakers should be fine. Best of luck finding the right pair.
I used Klipsch Heresy I’s and Polk Audio Monitor 7’s for extended amounts of time with a 1060 I had, and it worked well with both. I preferred the Polks by a good bit, however.
Need more info.
Budget.
Size of room.
Style of music.
etc...
Hi everyone! Thank you for some of your responses in such a short amount of time. Budget wise, I would like to spend no more than $300... definitely not more than $500. In terms of the size of the room, at this time, I'm thinking a bedroom. Desired volume levels... definitely enough to fill a bedroom. Bookshelf size if possible! I hope that helps!!!
That helps!
Hopefully now you'll get some good recommendations.
Your budget does allow for some decent/good current speakers as well as some good vintage ones.
Vintage, due to weight/shipping costs, may limit you to areas close by. New offers a wider net to be cast possibly.
Depending on your location vintage might be something to consider. Some markets are better than others.
How would vintage/new KEF's sound? Klipsch reference series a good match? (the new ones)? I keep hearing that if you have an old receiver/amp like a Marantz 1060 then it would be best to also get vintage speakers to match? But I don't feel confident in buying off the net used speakers because I'm worried I'm going to get disappointed so I'm looking to see if there are any newer speakers that would help give me that complimentary sound that many mention they hear when they use vintage speakers.
Hi and welcome to AK!
A couple questions. Are you handy? Have basic tools? Can you solder?
I don't want to overwhelm you, but some info you should know before buying vintage speakers.
If you decide to go vintage, there's a good chance you will need to do some work on them. Usually the old caps need replacing as they are out of spec, woofer surrounds have rotted and are gone. The woofers will need new surrounds installed. Most speakers in the smallish book shelf size have relatively simple crossovers, making cap replacement fairly easy. There are tons of videos showing how to replace woofer surrounds. Not to difficult to do, but you must be very careful to center the voice coil when gluing the surrounds to the woofer frames, known as baskets.
Some vintage speakers like KLH and AR have cloth surrounds. They don't need replacing, but often need resealing with a brush on sealer. They have simple crossovers, and are excellent sounding when restored.
ADS is another great brand, with great sounding speakers. There are a ton of models that would suit your needs quite well. Generally, they hold up well, not requiring much work to enjoy them. Most use rubber surrounds so you don't need to worry about replacement. Their crossovers are a bit more complex, but they used good film caps and usually a lytic cap that is usually ok, but would be a good idea to replace at some point.
I have all three brands I mentioned, and all are excellent. Many can be found well within your budget.
Newer speakers also sound great, are usually much smaller than vintage "book shelves". The obvious benefits are they won't need restoration work, but many may need a small sub for the deep bass we all love. This will add to your budget, but doable.
If you decide to go new, read reviews for speakers in your price range, then ask for opinions here from actual owners. You'll get much better feedback than from manufacturers marketing hype.
This is an addictive hobby, extremely enjoyable searching for and restoring various projects as you get into it more.
Glenn
Your local Craigslist is flooded with good candidates. Just go ahead and submit a few that appeal to you. If it's a dud you will be duly informed as such by several people. That's how you will know without question it's a loser. The info is in the consensus if it goes in that direction.
On the other hand if it's a winner, well that's when the fun starts.
For the Marantz I’d say go something vintage, JBL L19s can Be found in your price range, and I’d bet would be a great match.
Decade 16s - would be your best bet if you can find them.
4301Bs - if you can find them for 500 I’d say do it...
4401s small and sound great..
B&W DM12s
M&K 2b
Snell K and or J
Pioneer S-X4G
Klipsh KG2
Hope you find a set that works for you :)
Pretty much any older JBL, and you could also look at Klipsch Kg4’s they’re a bit bigger, but sound wonderful. And they are easy to drive with 30wpc
Have you looked at this thread....might be some helpful info as it's about speakers in your price range....
http://www.audiokarma.org/forums/in...pair-bookshelf-speakers.847539/#post-12192068
