Which to buy?
jeff's eight
I am about to make my first entry into the tube world.
The two considerations are both Integrated Amps:
1. Rogue Magna Cronus 2 $2,500 100wpc
2. Jolida 1000? ( Closeout $1,800 also 100wpc)
I understand the Rogue to be the better piece
but is it by $700? Is there something else I should
consider?
Thanks,
Jeff
I would prefer a push pull amp to parallel push pull.
But the thing I don't like from the Rogue is that the preamp tubes are more than half hidden under the chassis, hard to replace.
PS: You can use socket savers for those preamp tubes, that can help to be easier to replace them .
