Which Turntable Should i get?
ImAnonymous
Hello! I am new here, I know this has probably been asked a million times but i am looking to upgrade from my cheap Victrola Turntable (I am aware its not great) to Something better as i slowly upgrade my setup from all ultra-budget to something far better. My current contenders within my budget are; The U Turn Audio Orbit Theory in walnut with the 2m Blue cartridge, The Technics SL-1500C, and the Rega Planar 3. If anyone else has suggestions for other turntables within the budget those are welcome.
Orbit theory
Rega Planar 3
Technics SL1500C
Rega, IMHO. Way above the Orbit. Don’t know about the Tecnics. But I’ve heard Rega turntables and they are extremely good.
Easy as a resale if you decide to go up the Rega line.
Agree with the Rega...back when I joined here I subsequently purchased an RP-1 with the Rega Carbon cartridge. It was excellent, only reason I traded up was because "I could" before that option ran out with the dealer.
I guess the Planar P3 is a much better turntable, but the RP-1 was very nice.
That said, the Technics with the Blue Ortofon cart seems to me to be a whole 'nother level up! If ya got the budget...;)
Thats sort of what i was thinking, just wanted to have some people within the hobby validate that. Thanks.
"Within the budget": you'd need to mention which country you're in. Rega generally costs significantly more in the United States than in the European and some other markets. If that affects you, do you want to pay a premium for Rega ownership?
If you get the basic Planar 3 (without off-board power supply), there is no electronic speed switching: the power supply provides that - at extra cost - along with more precise speed control. A direct drive turntable like the Technics provides all that from the start. Even after the Neo PSU is added to the Rega, it can't match the accuracy of the Technics; that's just in the nature of belt drives, and the Rega's low torque motor.
Do you need the extra accuracy? Arguably not (though I'll take it if I can get it), but it's better to at least be aware of this, especially if considering a Rega power supply, as its key function (and selling point) is to improve precision. Also, the manual method for switching between 33.3 and 45 rpm is cumbersome: lift off the platter, move the belt to the appropriate location on the pulley, remount the platter. Do it all again when you want to change back.
Finally, I wouldn't myself consider resale value as a factor in my purchase, - I never do - and again, it would vary considerably from one country to another.
Orbit theory
Rega Planar 3
Technics SL1500C
I was curious about the price differences, and in my market area the SL-1500C is $1499 with a 2M Red, the Planar 3 can be had with a low-profile 2MR Red for $1224, and the Theory comes with a 2M Blue for $999.
Years ago, and living in an area where I was lucky enough to have half a dozen specialty audio shops nearby, I chose the Rega RP3 because it was clearly the best sounding turntable to my ears that I was able to audition in that price range and gave away very little to models up to twice its price. I also auditioned the outboard power supply, which I found to be totally unnecessary. Do you live in an area where you have a chance to audition some turntables, or, like me where I'm living now, do you need to depend on published reviews, customer comments, and forum discussions?
Turntables do sound different. One review site I enjoy is What HiFi, and their SL1500C review included comparison with the Planar 3, "Compare the sound of the two and it’s obvious that the Rega is even subtler and more insightful. It renders levels of sonic texture, dynamic subtlety and rhythmic cohesion that even the hugely capable Technics can’t match. But, it’s not all one-way traffic. The SL-1500C’s presentation is crisper and has better defined leading edges while at low frequencies it makes the Planar 3 sound a little soft and ill defined." Either could be seen as better than the other; it just depends on which sonic attributes are most important to a person.
All the models in your list have received very favorable reviews. From what I've read and from past experience, I'm reasonably certain that in direct comparison I would find the Rega most to my liking, but I'm also reasonably sure that with any of the three I would get a great deal of pleasure from my records.
Some in this forum really enjoy cartridge swapping, having different options ready to go on different headshells. If this is of interest to you, the SL-1500C certainly has an advantage here. It also has a built-in phono stage, which may or may not come in handy as you make other changes to your system. Reviews vary, but What HiFi's said, "Surprise number one is that the built-in phono stage is really good. That doesn’t tend to be the case normally, and means that you don’t have to spend extra on a dedicated outboard unit to get the best from the record player."
You asked about other options, and I was curious about the $1299 AT-LP8X. What HiFi made a comment comparing it to both the SL-1500C and the Planar 3, finding, "Ultimately, judged purely on sound, both the Technics and Rega packages still sit higher in the pecking order, thanks to their greater dynamic punch and rhythmic prowess. Both of these players, but the Rega in particular, are great at pulling the listener into the music. They deliver a more emotional musical experience, and ultimately, that matters most to us."
You hint at upgrading your whole system, in which case it might be worth thinking about one of the 80s Technics decks and put a VM95ML on it, then using the money saved over a 1500C elsewhere (speakers perhaps).
This approach should give more bang for the buck and you can likely sell the deck for near what you paid for it later - whilst enjoying probably better sound that the stock 1500 meantime thanks to the ML
There are fully automatic options also like the Q303.
Or this in case the budget could be lowered quite a bit.
Orbit theory
Rega Planar 3
Technics SL1500C
Just curious how you use your current turntable. What is it connected to? Do you mostly listen through speakers (wired or BT) or headphones, or both? Once you start upgrading here and there you'll quickly realize how the pieces 'fit' together (or don't!).
I have a bottom-to-mid tier Technics (SL-D2) from the early eighties. It is older than I am, and still faithfully does it's thing.
That's the context for how I view this choice. The Technics may be the one-and-done buy for the rest of your life. Then again, maybe the Rega could be as well. But for me, I'd absolutely go Technics.
If there's a local shop that has an SL1500C or especially a CS, go and take a look. It's a something else in comparison! :music:
I'm starting to feel bad for the Rega, both the Rega and the Technics are great turntables for 'real' and imho satisfying Hifi results that won't 'break the bank'.
They're just experessions of different approaches, which one is closest to your liking is up for you to decide.
I do have a local Technics dealer.
But I don’t want to waste too much of their time until I’m legitimately in the market. I’ve had this discussion with my wife, and she actually finds $1,500-$2,000 for a turntable to be reasonable if it’s in the buy-it-for-life context. (She uses it too). When the money is set aside and ready to go, I’m lucky enough that auditions are a ten minute drive away. :banana:
