Didn't realize so many here had one (or two) of these great amps, its great to hear as I don't see or hear about many out in the wild. Here's my HK250 with a matched quad of (TS) RCA 5881's (4/'72), and pair of RCA 6CG7 clear top/black plate; sounds really nice with them, but I have yet to hear the amp with 6L6's in it, which I need to try.
My amp came from a fellow (& nice) AK member, and had been serviced under the hood, with 5 way binding posts, and on/off switch added; I've had to replace some of the orig. resistors in the past, and reflowed some of the soldering.
Recently, one of the bias pots started to drift, not hold bias properly, so I changed both of them out; if I remember correctly, they're 100ohm? if replacing (recommend checking them), I would replace both and make sure the two new ones measure closely to each other (something you can ask the part seller to check when buying), the space is a tight fit, so make sure you find the right ones and measure dia. Also recommend making some contact points on top of chassis for your meter to check the bias while adjusting, to avoid having to always go inside to measure when biasing.
Great imaging and soundstage, musical; nothing glaring to complain about. It holds its own in very good company. I say it's a sleeper.
Enjoy your amp!
PS: I can't say for sure but I believe it's copper coating over steel chassis.
