Who works on tube amps?
centexguy99
Grumpy Old Hermit
I have a Stromberg Carlson ASR-120 amp that I would like to have recapped and power switch/input/output terminals installed on. If it was 30 years ago I would do it myself but my vision limits what I can currently do. Most of the time I spend on the site is in Solid State so I am not familiar with who the tube gurus are here. Any help would be appreciated.
I know a fellow in the Fort Worth area that does good work. If you want to ship it here send me a PM and I will give you his info.
I have done several of those amps. They are really pretty straight forward. The toughest part is making he wires before you remove the circuit card. Don't try to recap/re-resistor the circuit board in place. That is nuts. I know. Completely remove it from the unit. I also usually replace many of the shorter wires so that the board is easier to get in and out.
