crooner
Tube Marantzed
240 Volts said:I have noticed that Pioneer specify output powers for their SX-x3x, SX-xx50, and SX-xx80 receivers into both 4 and 8 ohms, except for the SX-1280 and SX-1980 for which output power is quoted into 8 ohms only. Similarly, the SPEC 4 is rated at 150 watts into 8 ohms and 180 watts into 4 ohms, whereas the output power for the larger SPEC 2 is only quoted into 8 ohms (250 watts).
My suspicion is that this is because the cooling on these higher power units is insufficient to allow them to develop the same (or greater) continuous power into 4 ohms as they can into 8 ohms (output power being measured by the old FTC regulations which required 1 hour pre-conditioning at 1/3 of rated output, i.e. maximum heating of the output transistors).
Inadequate cooling is not a reason for the lack of 4 ohm ratings. The real reason is that at 4 ohms current draw increases considerably and many of these models had a safety limiter to prevent damage to the output transistors.
The SOA of high power transistors in the 1970's was still limited at lower loads. There were "brave souls" such as Flame, I am sorry, Phase Linear that used them to their maximum capacity. However, the Japanese placed utmost importance in safeguarding equipment, hence the current limiters.
The units can actually be used safely with 4 ohm loads, only that doubling of power at such loads is not possible due to the limiter. THD probably creeps a little bit as well. Remember back then manufacturers were in a THD race. Nobody wanted to show higher THD levels at 4 ohms for about the same power available at 8 ohms.
