restorer-john
Addicted Member
....enter, the 1987-1990 pioneer a-717. just wow. its bass is so fluid, natural, and reverberating. you can hear some of the most delicate sounds with utter precision. i would have to imagine its close to what people like about tube amplifiers. the a-910 barely scratches the surface of the low notes that the pioneer can just flood the room with from sheer woofer movement. the pioneer made two bose 201’s send heavier low frequency tremors through my floor than the nec can with both bose 201’s and mcs 3895 bass reflex speakers. its almost as if the nec is stationed above ground trying to lift the lower frequencies out whereas the pioneer was already underneath the ground pushing the low frequencies out from underneath themselves..
so does that mean the super healthy, rotel slaying, a-910 needs a recap? or does it mean the a-717 is just a higher fidelity amplifier than the 910 and MUCH more than the rotels and EXPONENTIALLY more than anything less than the rotels that led me on this quest to better conquer my existing gear??...
I have a mint in box Pioneer A-717, bought when they were run out back in 1989/90, an A-616 (it's smaller brother) and the big one, the A-91D. It is true, they have a phenomenal bottom end, but they are ruler flat. I am about to run some tests on my A-91D as soon as I make space on my bench and practice weight lifting (it's 29.9kg).
Rotels are lovely, but they all rolloff the low octaves, regardless of their vintage- it is a Rotel characteristic- very British in their rolled off top and bottom ends.
Bear in mind, frequency response specifications can be very misleading. They are all specified at 1 Watt. What happens with many amplifiers is the bottom and top ends roll off more and more as the output power increases towards rated power. Power bandwidth specs help a little, but even they are deceptive as it is a spec where half power can be achieved, not full power.
Basically, full power frequency response tests are needed. Nobody really does them, but I can tell you, they sort the amplifiers out faster than any other test. And, in reference to this thread, it's the high power sweeps that show the differences with recaps. THD improves often very significantly with recaps, especially where VAS stage rails were getting modulated by power stage current demands.
Back to the thread subject.
There is no doubt that sensible replacement of aging electrolytic capacitors is warranted on a lot of vintage gear. Improvements in many areas of performance are easily demonstrated and measurable. Some of the more recent vintage gear will not show much if any measurable improvement, but nobody could argue that high quality brand new capacitors are preferable to 20-30 year old capacitors. Preventative maintenance.
