aabottom
Swing
For fun, I've been collecting rabbit ears at the thrifts. I find them now and then for 1 to 5 bucks. My collection is now up to a grand total of three. One is a more modern one from RadioShack (Model No. 15-1828) and has a female F-connector on the box to attach standard 75 ohm CATV cables (RG-6, RG-59) with male F-connectors. The other two likely came off an old TV set and have a short length of 300 ohms twin lead cable attached.
Rabbit ears can be formed into half wave dipoles that are resonant with the FM band (and some TV bands). Half wave dipoles have a nominal input impedance of 73 ohms [1] that matches the impedance of 75 ohm CATV cable well, although a balun is required to reduce common mode currents that cause the coax line to radiate in addition to the antenna itself.
On one of rabbit ears, the 300 ohm twin lead is attached directly to the dipole antenna elements- a direct impedance mismatch to a 73 ohm half wave dipole. The other I haven’t taken apart for fear of damage to the case. I wonder if it has a balun/transformer (73 ohm to 300 ohm) inside the tiny box.
So my questions are:
Why do "vintage" rabbit ears come with 300 ohm twin lead cable?
Does the short length of 300 ohms twin lead cable attached form some sort of RF impedance matching circuit? Maybe I’ll have to get out my textbooks to answer this one.
On my FM tuners, do I connect these to the 300 ohm or 75 ohm antenna terminals?
Any comments?
I’m thinking about modifying them to attach a 75 ohm CATV cable with an air-core balun [2].
[1] http://en.wikipedia.org/wiki/Dipole_antenna
[2] http://hamuniverse.com/balun.html
Addendum: Here's a photo of the RadioShack Model No. 15-1828 (top) with CATV cable screwed into the female F-Connector and the Sony AN-18 with 300 ohm twin lead permanently attached (bottom).
Any comments?
